11 years agoNo output data of CVI IP core.
Hi guys,
First off, I just started using FPGAs about a month ago, and am only just beginning to use Nios II and IP Cores, so suffice to say I am very new to this. I'm working with CVI IP core to convert the input video from PAL Camera to Avalon-ST video stream,followed by a Deinterlacing IPcore.However,though CVI successfully detected the input clocked video,there is no output. but when I replace the CVI with Test Pattern Generator IP Core,the datapath works successfully,which has confused me for a long time. If you've successfully used this in the past, please have a quick read and see if you can help me out. Thanks a lot!3 Replies
Anyone? I have problems with clocked video input IP as well...
Thanks in advance. - Altera_Forum
Hi Richeal,
I has been a while since you posted your issue, but I was wondering whether you fixed it or not? I have clocked video input working now so I might be able give you some pointers by now. Grtz, Richard. - Altera_Forum
Hey Guys,
I am also seeing the similar issue. I do not see any output on the CVI block. I have signal tapped and verified the input to the CVI block and input seems to be fine. Any inputs? Regards, Hanumanth
