14 years agono free buffers for rx
Hello How do i increase the receive buffer size.... till now i have done following... 1. increase the receive Depth of TSE Mac... 2. Increase the MAXBIGPKTS from 30 to 512 in "ipport.h" ...
14 years agoIt seems that SOPC Builder isn't able to map the peripherals in your system when forcing the bridges to address 0 to prevent an address shift. It is strange, in my experience this always worked...
I tried a different strategy. I unlocked all the bridge addresses, and saw after the base address assignment that there are two block that use two addresses: ddr2_bot and descriptor_memory. I collapse all the components (View menu) to have a better overview. Upon a first look I saw that you had some pipelines that weren't very useful. If you use a clock crossing bridge you don't really need to combine it with a pipeline bridge. So I removed pb_dma_to_ddr2, pb_cpu_to_io and pb_cpu_to_flash. Then I reran an assign base address. Then I right click on ddr2_bot, go to connections > s1 and see that it is connected to pb_cpu_to_ddr2_bot and ccb_dma_to_ddr2. Since locking those two bridges to 0 didn't work I tried to do the contrary. I locked the pipeline bridge from the cpu to its current address (0x08000000) and modified and locked the address on the other pipeline bridge to match. Then I did the same thing with the descriptor memory. I locked the ccb_cpu_to_io address to 0x10000000 and modified and locked the pb_dma_to_descriptor_ram to the same address.
