16 years agoNios+PCI doesn't work together, help.
I create Nios+PCI compiler (PCI target 32-bit) system on Cyclone II. When PCI is connected, Nios doesn't load any software, but works good without PCI. I've made PCI in reset, without clk - doesn't h...
16 years agoby the way ,I find my pci t32 ip can not support brust transaction, PC read some words from sdram which connect to the pci ip , in SignalTap I find the PC read word one by one . that is so slowly.
at last I find "Reads originated from an x86 (Intel) architecture CPU destined to a PCI slav e device (such as PLX 9050) will never be bursted. This is a x86 IA32 limita tion." this is the addr of this words http://learn.tsinghua.edu.cn:8080/2004210935/bm/csarch2000-4100/1368.htm I do not known whether your pci t32 has this condition or not.
