16 years agoNios+PCI doesn't work together, help.
I create Nios+PCI compiler (PCI target 32-bit) system on Cyclone II. When PCI is connected, Nios doesn't load any software, but works good without PCI. I've made PCI in reset, without clk - doesn't h...
16 years agoDo you use the pci mt32 core ? I use it with the "user guide" saied,(by the way,which is with the sopc builder flow) but in the PC ,can not find the pci device,
before, I used the pci t32 connected to sdram with the sopc builder flowing ,it worked well. can you help me? thank you
