16 years agoNios+PCI doesn't work together, help.
I create Nios+PCI compiler (PCI target 32-bit) system on Cyclone II. When PCI is connected, Nios doesn't load any software, but works good without PCI. I've made PCI in reset, without clk - doesn't h...
16 years agoI'm using both PCI Master-target 32 bit 33MHz and Nios II in my design. How you connect your PCI component and NIOS II in your SOPC? What is your PCI Clock/Reset Setting? Did you assign your reset address correctly?
