18 years agoNIOS2 DDR2 refrence desing
Dear friends,
does any body have solution for NIOS2 DDR2 in sopc builder, i tried with ddr2 documents but during complilation timing error, i dont know why, pleaese help me. if any body have refrence design, please upload here, i am using custom statrix II board. regards, baba5 Replies
I think you are profession in my issues, I need your help. I have some troubles with my design with Stratix II devices. I use MegaWizard, Quartus's Web edition, to create ALTMEMPHY. It releases many files such as: *_alt_mem_phy_reconfig_sii *_alt_mem_phy_ sii alt_mem_phy_defines alt_mem_phy_sequencer.vhd *_altmem_phy_sequencer_wrapper.vo ... Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module? To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice. I'm very impressed by ALTMEMPHY but I can't use it for a long time. Thank you in advance! - Altera_Forum
today is friday, 7.30 pm, so, detail solution tomorrow , no problem you can beat that
What timing issues are you running? What messages do you get within SOPC Builder or the Quartus II Compilation?
More info buddy - Altera_Forum
Hi babaship,
What is the error message? I think that You must delete the following files list and regenerate your NIOS system. - add_constraints_for_< >.tcl - auto_add_ddr_constraints.tcl - auto_verify_ddr_timing.tcl - ddr_lib_path.tcl - remove_add_constraints_for_< >tcl - verify_timing_for_< >.tcl - Altera_Forum
--- Quote Start --- Hello, I think you are profession in my issues, I need your help. I have some troubles with my design with Stratix II devices. I use MegaWizard, Quartus's Web edition, to create ALTMEMPHY. It releases many files such as: *_alt_mem_phy_reconfig_sii *_alt_mem_phy_ sii alt_mem_phy_defines alt_mem_phy_sequencer.vhd *_altmem_phy_sequencer_wrapper.vo ... Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module? To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice. I'm very impressed by ALTMEMPHY but I can't use it for a long time. Thank you in advance! --- Quote End --- Hi tuanna, You can simulate your NIOS system by using SOPC Builder. It can create a simulator project.
