11 years agoNios Floating Point Hardware 2 and ROM usage.
Hi, I am trying to use the Nios Custom Instruction Floating Point Hardware 2 module, and I am targeting a MAX 10 device. The MAX 10 allows you to use a large portion of the flash as User Flas...
11 years agoCan I ask how did you know that the module required ROM tables - did you get an error from Quartus when compiling without RAM pre intialisation?
What did it say? I'm wondering if other IP modules might need ROM tables and hence how we see/detect that in a Max 10 build. I'm sure some of the DSP IP uses ROM tables.....
