17 years agoNios CPU read FIFO
Hi, all I'm trying to use Nios CPU to read data from a FIFO via Avalon interface. However, when I read data through a pointer which points to the FIFO base address, the data are constant and th...
17 years agoMy Nios II CPU has 64kB instruction/data cache since I would like to have a high implementation speed. The burst mode is also enabled. It reads the FIFO data using a pointer which points to the FIFO base address.
I will try your suggestion. Thanks! However, I'm confused about the address issue. In my understanding, operating a FIFO has nothing to do with the address.
