15 years agoNewbie Question: Access DPR outside SOPC Builder
Hi, I'm currently having trouble to set up a connection to a megawizard created Dual Port RAM. I want to make it accessible from within NIOS as if it was a normal RAM inside NIOS-II via a DMA m...
15 years agoHi andreg,
Probably you have an error in tx_chan address and you are making dma transfer from the wrong memory area.. Is the tristate bus width 32?
