15 years agoNewbie Question: Access DPR outside SOPC Builder
Hi, I'm currently having trouble to set up a connection to a megawizard created Dual Port RAM. I want to make it accessible from within NIOS as if it was a normal RAM inside NIOS-II via a DMA m...
15 years agoHi andreg,
I had the same need as you. Please refer to the following thread I started last month for some ideas: http://www.alteraforum.com/forum/showthread.php?t=24965 Actually, I eventually ended up with a different and simpler approach. I instantiated the dpr external to the sopc system and used the sopc tristate bus to access it. In my design this was enough; maybe this is not good for your case if you have strong performance requirements. Regards Cris
