13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years agoMy problem with the performance counter block is that it is a 16bit slave - so it takes a lot of accesses to do anything.
A 32bit version would be much more friendly. The lack of 'add with carry' could well be a problem, but one of the cmp instructions would do the job. So code like: sum = a + b + carry;
carry = sum < a; is amost right (needs an extra check for b[i] + carry == 0). So 5 instructions (+ memory access) including 1 branch that can be staticly predicted 'not taken'. With care and a combinatorial custom instruction (or 2) could be 3 instruction (I think).
