13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years agoEven if it were supported / popular, I don't think C2H approach will be a good fit for you.
For starters, I think what it will try to do is generate a non-bursting Avalon-MM Master with 32-bit width for reading, writing your data. So you will spend many clocks loading/storing, and then it will generate possibly a lot of HDL to make your math execute in a single clock. Overall, I think you would not be satisfied with the result.
