13 years agoNew IP development
Hello, I am interested in developing some instructions which can do the bignum operations (like adding two operands of 1024 bit) and hence by plan to implement a simple Full Adder like this: ...
13 years agoYour block diagram looks OK. The bottleneck is going to be the "operand A" path from NIOS to onchip memory. I'm not familiar with the specific algorithm you are implementing: is "operand A" going to be generated from the body of a nested loop, or is it going to be generated only once (as an input parameter) before the algorithm/loops execute?
