12 years ago(need help)3X3 Hardware Matrix Multiplier as QSYS custom component
Hi, Currently I was trying to make a custom component(e.g.Hardware matrix multiplier) in qsys using Avalon MM interface. But I'm confused how to send two matrix into my component and to solve...
12 years ago --- Quote Start --- If you use an "address" signal on your Avalon MM slave interface, then you can create several registers to hold all your values. --- Quote End --- hi Daixiwen , sorry ! I didn't understand what you mean to say. Can you please explain the procedure little bit.
