18 years agoNeed help with DE2 Audio Codec
I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there is much noise along with the music from the headset? Thanks for help!
12 years agohey what code are you used? and what kind of filter you used? can you send me the codes for both.. thank
