18 years agoNeed help with DE2 Audio Codec
I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there is much noise along with the music from the headset? Thanks for help!
14 years ago --- Quote Start --- Can you please mail me your VHDL code for control interface of AUDIO CODEC?..THANK you --- Quote End --- Hello, can i have your VHDL code for the bit configuration of AUDIO CODED as well ? Your help will be much appreciated :)
