18 years agoNeed help with DE2 Audio Codec
I set up everything as in the DE2 manual, and use the reference design to play music(48KHZ,wav). But why there is much noise along with the music from the headset? Thanks for help!
15 years agoHello, i am having the same problem with the SD card, there is considerable noise level on the output, so is there any workaround for this?
Thanks!
