13 years agoNeed help to make Triple Speed Mac's avalon-MM interface work.
In my now doing project, a altera Tse mac without sopc/os is used, I wanna to use only the Tse with udp/ip stack in a very fast image grab application. Basic hardware is Cyclone III + 88E1111(GMII...
13 years ago3x for replay, I have tried to use a external pin as the reset signal ,first tie up, then after I watch 100M, 125M clocks ok, pull the pin low, so I am sure reset time isn't the problem.
Tse don't get clocks on the phy side, only GMII interface needed signals connect between Tse and Phy, tx&rx clks all from Tse side. As I know, Tse worked under mulit-port mac mode need tx_clk/rx_clk for data trans and clk for alavonMM, are there any other signals need?tell me if you know.
