13 years agoNeed help to make Triple Speed Mac's avalon-MM interface work.
In my now doing project, a altera Tse mac without sopc/os is used, I wanna to use only the Tse with udp/ip stack in a very fast image grab application. Basic hardware is Cyclone III + 88E1111(GMII...
13 years agoFirst be sure you wait long enough, the TSE's initialization phase can take several thousand cycles IIRC. If waitrequest stays up for more than that, then it means you have a problem.
Is the TSE getting clocks on the PHY side too? It has some clock domain crossing logic inside, and the reset cycle will only complete if the TSE gets all its clocks.
