10 years agoNeed example using OpenCores MAC on DE2-115
Hi, all,
I am trying to use Avalon OpenCores 10/100 Ethernet MAC developed by jakobjones on a DE2-115 board but no success. I followed the document of jakobjones to connect the MAC in Qsys and tried to run a simple socket server in Nios II IDE with ETH_OCM_PHY_SUPPORT_MVL88E1111 symbol defined. But I met two problem getting the example running successfully. 1. The Nios II project generated by Nios II IDE contains a tse_my_system.c file, which includes tse driver files that don't exist in the BSP. 2. If I exclude that tse_my_system.c file from Nios II build, I could get the simple socket server to run but I keep getting DHCP timeout. I also tried static IP but still no luck.InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
Your Ethernet MAC address is 00:07:ed:ff:cd:15
prepped 1 interface, initializing...
mctest init called
IP address of et1 : 0.0.0.0
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4) Could anyone kindly help me by showing me a working design example of OpenCores MAC on DE2-115 board? Thank you in advance for your help. Best regards, goosechenNo RepliesBe the first to reply
