16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine wave...
16 years agoWould it be a problem in hardware implementation if the clk is 125MHz where the previous transition is very near to the next rising clock? If possible, i am trying to use megafunction instead of design a new pipeline CORDIC.
