16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine wave...
16 years agoUnfortunately, we can't clearly recognize the delay in your various waveforms, because the sending clock edge can't be seen. So we can only guess about possible timing violations. As said, the timing analysis should clearly tell.
