16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine wave...
16 years agoI have run the low freq simulation which is 25M clk. It is fine. However, if i run at the 125M, it violates.
any reason to cause this? Thanks
