16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine wave...
16 years agoAre you sure, that the transition isn't caused by the previous rising clock edge? Run the design at a lower clock frequency for clarity.
