16 years agoNCO:Sine Waveform
Hi. I am trying to use the NCO to generate the sine waveform. However, the waveform obtained is different where it is attached. May i know where to modify it in order to get the correct the sine wave...
16 years agoI add some minimum of phase dithering into the signal. The signal is slightly improved.
There result confuses me on the output. The result change state before the rising clock. Besides, i add a register output, the output still change before rising edge. I am pretty sure that the transition state is on rising edge of the clock because i do functional simulation on it Can someone explain to me? Thanks a lot
