19 years agoNCO Megacore Phase Adjust
Hello I am using the Altera Megacore NCO Compiler and need to dinamically adjust the phase of the generated sine wave. The core has an input called phase_mod_i[] which is used for this purpos...
13 years ago --- Quote Start --- Hi, i'm a student university and i made a QPSK modulator with Altera Stratix II and i don't understand how set NCO for an phase modulation and how define the constallation mapper.... thx for support --- Quote End --- The steps for qpsk are: get your data bits(0,1) as pairs map pairs to two separate I,Q streams (as +1/-1) shape the pulses but I assume this step is too much for Uni student so ignore it multiply each of I,Q streams by cos/sin in a complex multiplier(mixer) The output of multiplier will be the modulated qpsk (centerd on your chosen nco frequency) The +1/-1 will simply invert or leave the phase of your cos/sin (0 or 180 degrees)
