19 years agoNCO Megacore Phase Adjust
Hello I am using the Altera Megacore NCO Compiler and need to dinamically adjust the phase of the generated sine wave. The core has an input called phase_mod_i[] which is used for this purpos...
13 years ago --- Quote Start --- Hello I am using the Altera Megacore NCO Compiler and need to dinamically adjust the phase of the generated sine wave. The core has an input called phase_mod_i[] which is used for this purpose. The problem is that I don't know the relation between the desired phase adjust (in degrees) and the number I need to input in the core. Is it linear? As in: Input (with 15 bits of angular precision) / Phase Difference (degrees) 000000000000000 / 0 100000000000000 / 180 111111111111111 / 360 (or 0) Can anyone help me please? Thank you Thiago --- Quote End --- Hi, i'm a student university and i made a QPSK modulator with Altera Stratix II and i don't understand how set NCO for an phase modulation and how define the constallation mapper.... thx for support
