19 years agoNCO Megacore Phase Adjust
Hello I am using the Altera Megacore NCO Compiler and need to dinamically adjust the phase of the generated sine wave. The core has an input called phase_mod_i[] which is used for this purpos...
19 years agoThiago,
phi_inc_i should be constant zero, in order to eliminate the phase incrementing as time clocks by. phi_inc_i is the frequency and you want that to be zero. In this way the object of your study, as I understood your question, the phase_mod_i[] is the sole contributor to the output, improving tremendously the visiblity. Clear? If not, ask again. henning
