15 years agoNCO MegaCore Function
Hi, If I want to generate the fixed amplitude and Fixed Frequency statble Sine Wave, is NCO MegaCore Function is the right choice? Outof the following Generation Algorithm Small ROM ...
15 years agothe different generation algorithms are largely a resource/time trade off
if you have lots of extra RAM in your design, choose one of the ROM based NCOs if you have lots of logic leftover use a parallel CORDIC if you've got a high clock rate but low sample rate use a serial CORDIC if you've got some multipliers left over use a multiplier based a common specification for NCOs is spurious free dynamic range SFDR. you can get an idea of what you can achieve in the MegaWizard when you vary the parameters
