16 years agomultichannel FIR output timing error
When I use multichannel fir filter, the timing of output channels is not correct. The output generated by 1 channel shifted. For example, First channel data filtered out to second channel, second ...
15 years agoI have checked and checked and the inputs to outputs are reversed
I with SOP & Valid, Q with EOP & Valid go in Q with SOP & Valid & Channel 0, I with EOP & Valid & Channel 1 comes out Anyone?
