16 years agomultichannel FIR output timing error
When I use multichannel fir filter, the timing of output channels is not correct. The output generated by 1 channel shifted. For example, First channel data filtered out to second channel, second ...
15 years agoDid either of you find a solution to your problem?
I have a two channel filter but have only been putting signals into channel 0. I have been debugging a DC block module. Eventually I decided there was a timing issue on the input (output of the FIR). With a bit of messing I found the signal appears on channel 1. Is this the same as what you are seeing? I have to make a few hardware modifications to my test boards before I can stuff a signal into channel 1. my dc block simulates ok. I use Altium Logic Analyser (which is the same as signal tap, i think). any advice? Quartus 9.2, 2 channel, decimating by 8, parrallel update- I have connected channel 0 and it seems that the output is swapped. That is, I is on channel 0 and Q is on channel 1, feeds the FIR. The output is Q channel 0 and I on channel 1. The actual filtering and data signals are fine. I have probably crossed my Is and Qs somewhere. I shall recheck the input to the FIR, but the output is definitly as above.
