16 years agomultichannel FIR output timing error
When I use multichannel fir filter, the timing of output channels is not correct. The output generated by 1 channel shifted. For example, First channel data filtered out to second channel, second ...
16 years agowhat version and what parameters?
can you just stick an impulse into channel 0 and grab a SignalTap with the input and output?
