10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agoDear Sirs,
problem solved with service request help. Problem was in reset_n signal. After power up filter must be reseted! Also after filter reset we need to wait few clock cycle before we assert sink_SOP signal. Best regards Adam
