10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agoI think this is not truncation problem because when i use 60MSPS in some test results is ok.
Pchittenden can you check results without decimation? I use quartus 15 and 16 but problem is in both. Still noo progess.
