10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agoI assume sop is first channel, eop is last channel (as if you are giving channel number that way)
