10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agoDocumentation say i need sop/eop and valid. When i use only one channel there is no sop eop but when i change to more chanels then i have sop eop and valid. I do evrythink like in documentation but result i wrong when i use les than 60MSPS.
