10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agoI have done filters (and fir compiler) but only needed (data, valid input and possibly channel number). I don't know of any meaning for frames as filtering is not frame based but continuous stream. So what does the tool say about sop/eop? I don't know. You are using them so you need to clear that.
