10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years ago --- Quote Start --- Dear Sir, i do what you say but there is same problem. Can you Sir upload some screen from simulation or signal tap how to exacly control SOP, EOP and valid sink signals? Maybe i do something wrong. Best Regards Adam --- Quote End --- I am not familiar with sop/eof for filters(but for fft) so can you ell me what is filter frame? I will send samples of two channels successively one after other. I know you can split them into frames but why?
