10 years agoMultichannel Fir Compiler ii problem.
Dear Sirs and Madams, I have some problem with Fir Compiler II. When i set max number of channels 2, Clock Rate 120MHz and Input Sample Rate 60MSPS filter works perfect but when i change input s...
10 years agowhen you set data rate that is not same as clock rate you need to raise valid input pulses one every data sample(zero otherwise). e.g. for 1 Msps on 120Mhz clock then you pulse it once every 120 clocks (or once every 60 clocks if two channels).
