10 years agoMulti-Port-Front-End DDR3 controller is too slow
Hi, I've using a Cyclone V SOC with 1Gbyte of DDR3 memory connected to the FPGA DDR3 pins - I've set the basic clock rate to 350MHz. I've got the NIOS CPU connected to this, and can verify that t...
10 years agoI don't have enough experience to address your specific case, but I can share some experiences I have had.
I've got a project on the Cyclone V (non SoC, but I'm going that direction next most likely) using the arrow BMCV board. This board has a 16 bit memory interface to the hard memory controller and it runs at 333 MHz if my memory serves me correctly. In my design I've got a MPFE with a 32 bit wide port going to a jtag bridge and a 128 bit wide port fed from my logic running burst length of 128 and I achieved about 80% of my calculated efficiency. I think I calculated that if there was no overhead for calibration or anything else that you could get 10.6Gbits/sec and after a lot of testing up and down I almost always had a hard failure at 80% of this (I varied clock and burst length). n my case the burst length seemed secondary, but to keep the overhead down bursting really does seem to make sense. It took me a while (and some help from an FAE) to get all of the avalon signals managed correctly. There's a KB article that hints at a possible explanation of the 80% in my case, but I never got a confirmation (it talks about losing a cycle due to scheduling every four cycles or something like that, but it doesn't really add up. I had really hoped to get into the low 90's but never figured out what the problem was so I had to alter my approach. I ran into similar issues with the FIFO resources. I did use beginbursttransfer in my design. So I guess I would expect you to be able to get a much higher efficiency in yours. In mine since one port is basically idle and the other port is as wide as I can make it with long bursts, I'm not sure it is a fair comparison. I have really only scrutinized the write bandwidth; I read it out much slower, but I'm constantly writing. -Lance
