10 years agomSGDMA response FIFO stucks if receives 256...512 bytes
I use Quartus II 64-Bit Version 15.02 Build 153 mSGDMA is used in ST to MM mode http://www.alteraforum.com/forum/attachment.php?attachmentid=11724&stc=1 in the Control register set bits DES...
10 years agoYes, it is low during every start of packet signal is set. When it was high, mSGDMA did not work. I do not know why it behaves this manner.
