10 years agomSGDMA response FIFO stucks if receives 256...512 bytes
I use Quartus II 64-Bit Version 15.02 Build 153 mSGDMA is used in ST to MM mode http://www.alteraforum.com/forum/attachment.php?attachmentid=11724&stc=1 in the Control register set bits DES...
10 years agoThere is something in fact, it looks like the read signal is low during your start of packet. Looking back at the other figures, I see that valid is also low each time you have a start of packet, making it not recognizes by the stream sink. That could be what makes the DMA behave strangely. Do you know why the valid signal gets low?
