10 years agomSGDMA response FIFO stucks if receives 256...512 bytes
I use Quartus II 64-Bit Version 15.02 Build 153 mSGDMA is used in ST to MM mode http://www.alteraforum.com/forum/attachment.php?attachmentid=11724&stc=1 in the Control register set bits DES...
10 years agoAren't you monitoring the ready signal in the stream source too?
