10 years agomSGDMA response FIFO stucks if receives 256...512 bytes
I use Quartus II 64-Bit Version 15.02 Build 153 mSGDMA is used in ST to MM mode http://www.alteraforum.com/forum/attachment.php?attachmentid=11724&stc=1 in the Control register set bits DES...
10 years agoYes, I'm using custom mSGDMA.
Below are screenshots of Signal Tap with 52 bytes, 232 bytes, 256 bytes per packet, zoomed to the end of the packet and the beginning of the next one: 52 bytes per packet http://www.alteraforum.com/forum/attachment.php?attachmentid=11732&stc=1 232 bytes per packet http://www.alteraforum.com/forum/attachment.php?attachmentid=11733&stc=1 256 bytes per packet http://www.alteraforum.com/forum/attachment.php?attachmentid=11735&stc=1 i do not see differences of waveforms
