10 years agomSGDMA response FIFO stucks if receives 256...512 bytes
I use Quartus II 64-Bit Version 15.02 Build 153 mSGDMA is used in ST to MM mode http://www.alteraforum.com/forum/attachment.php?attachmentid=11724&stc=1 in the Control register set bits DES...
10 years agoAre you using a custom ST source? Can you use signaltap to see if the data is flowing correctly on the streaming interface, respecting the start/stop of packet and ready/valid signals?
