13 years ago
Modular SGDMA
I am trying to make use of the Modular SGDMA IP with QSYS. Will QSYS generate the correct write/read commands in the test bench file, altpcietb_bfm_driver.v, to properly test the DMA?
I'm having difficulty figuring out which address to write to the dispatcher for:
- descripter tables
- CSR registers
- response registers.
QYS has
-CSR base at 0600_0000 to 0600_0600_1f
-Dispatcher base at 0600_0020 to 0600_0600_2f
How do the DMA registers fit within the above address map?
Thank you,
Rob
