15 years agoMODULAR SGDMA burst read issue
Hi everybody, I'm using PCI compiler 32b master/slave combined with modular SGDMA. I'm simulating system with modelsim 6.5. I'm using the Modular SGDMA dispatcher associated with the SGDMA r...
15 years agoThis sounds like a bug I fixed a while back, make sure you are using the updated version from here: http://www.altera.com/support/examples/nios2/exm-modular-scatter-gather-dma.html
If the one you are using has a 9.0 directory in the zip file then you have the old one that had a burst truncation issue in both masters. Make sure you pass a start addresses that are compatible with the word alignment settings you are using. For example don't select aligned addressing then pass in some location that starts on a byte boundary for example. Hacking the burst count is not recommended as there is a lot of logic dependent on the burst count (like the address incrementing logic). If it is still failing I recommend capturing a transfer with all the read master internal signals captured.
