15 years agoMODULAR SGDMA burst read issue
Hi everybody, I'm using PCI compiler 32b master/slave combined with modular SGDMA. I'm simulating system with modelsim 6.5. I'm using the Modular SGDMA dispatcher associated with the SGDMA r...
15 years agoThank you for your response,
Even with force burst alignment disable , I have the same problem. There is a strange thing : I need to change the burstcount value of read and write master cores (in VHDL sources). This value stay at '1' no matter "Maximum burst count" value, is that normal? But with read master core (after changing the burstcount value) I still have the incrementing issue. On the other hand, Write master core works well in burst mode, with same settings. So, if it's not a bug, what could be the reason (settings, word alignment...)? I tried with different settings in SOPC, but same problem... So if you have any suggestion... Thank you
