15 years agoModelsim: Simulating a whole SOPC-System
is it possible to simulate a whole SOPC-System with Modelsim? So that you can see the io's of some Avalon components e.g.? Thanks for every hint! Best regards2 Replies
Yes it is possible, refer to NIOS documentation on the Altera website. AN351 is a good entry point.
The only thing I can't simulate, it's the execution of the NIOS from an offchip (different than IDT71V416) SRAM as NIOS EDS doesn't generate the relevant .hex file, as it does when the execution is done from an onchip RAM... - Altera_Forum
Ok, thanks for your hint!
I've got a simple test design in SOPC-Builder: TestPatternGenerator -> ClockedVideoOutput So, there is no Nios, only these both components. I enabled "Simulation" in "System Generation Tab" and clicked "Run Simulator" and ModelSim opens. BUT, what do I have to do, that I can see the signals on the output of ClockedVideoOut or the Avalon signals? What is the next step, to see any signals? Do I have to write a testbench? But what does this testbench has to do? Only generate the system clock? Thanks for your assistance!
