13 years agoModelBus - RegField
Good afternoon, I have a nice DSP Builder model integrated with a NIOS II processor. Everything works well. I'm trying to use the RegField in the DSP Builder Advanced Blocks/ModelBus libra...
12 years agoDSP Builder creates a hw.tcl file which you can use to import your design into Qsys. If you have ModelBus blocks (or FIRs/NCOs with read/writable coefficients/increments), it will export a Avalon MM slave. If you write to the address you set in the Address field (possible misnamed Name in the parameter window) then you will modify that register.
